GE model 60 clock radio Static
I have disassembled both IF cans the trimmers are of the type where 2 plates are separated by a piece of mica and a screw going through the center. I took all 4 apart and saw no evidence of the silver mica disease the mica looked like a pane of glass nice and clean. I cleaned all 4 assemblies and put them back together, it made no difference. Next I cleaned the ant and osc trimmer on the tuning capacitor. Still have the problem.
Any thoughts or suggestions on where else to look?
GE model 60 clock radio Static - by Eric - 10-27-2015, 04:50 PM
RE: GE model 60 clock radio Static - by Eric - 10-28-2015, 10:13 AM
RE: GE model 60 clock radio Static - by Eric - 10-28-2015, 07:16 PM
RE: GE model 60 clock radio Static - by David - 11-01-2015, 06:43 PM
RE: GE model 60 clock radio Static - by Eric - 11-03-2015, 08:46 PM
RE: GE model 60 clock radio Static - by David - 11-04-2015, 09:06 AM
RE: GE model 60 clock radio Static - by codefox1 - 11-26-2015, 02:18 PM
RE: GE model 60 clock radio Static - by TV MAN - 12-16-2015, 10:35 AM
RE: GE model 60 clock radio Static - by Arran - 12-17-2015, 05:13 AM
RE: GE model 60 clock radio Static - by Eric - 01-24-2016, 12:03 PM
RE: GE model 60 clock radio Static - by Eric - 01-24-2016, 05:30 PM
RE: GE model 60 clock radio Static - by TV MAN - 03-02-2016, 02:41 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
