Philco 366 problem with filter choke
Part no. 32-7018
65 henries, 2250 ohms, 10 mA DC (according to the 1941 Philco parts catalog). As the resistance across your choke is less than 20 ohms, it is pretty well shorted out. And you won't find a 65 henry choke these days!
You can substitute a 2200 ohm, 2 watt resistor for the choke, and increase the value of electrolytic (49) from 6 uF to 22 uF. This may solve your problem. Many 1937 Philco radios used a similar voltage divider network to feed B+ to the IF screen grid and the 1st det-osc oscillator "plate", but these used a resistor, not a choke, to drop the B+ somewhat and act as part of a "pi" filter which included input and output electrolytics, just as in the 66. I have not tried this in a 66 or a 45 (same voltage divider circuit), so YMMV...but theoretically at least, it should work.
Philco 366 problem with filter choke - by Guest - 03-22-2009, 12:32 PM
Re: Philco 366 problem with filter choke - by Ron Ramirez - 03-22-2009, 02:11 PM
Re: Philco 366 problem with filter choke - by Guest - 03-23-2009, 12:34 AM
Re: Philco 366 problem with filter choke - by Guest - 03-28-2009, 01:42 AM
RCA T62 is playing.....
Philco 89 indicator light.
Philco 40-120C Restoration
Philco 91 Restore Code ??
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
So sometime  back I posted some photos of a badly damaged in transport T62, not the tank. I did manage to get a donor c...Paul Philco322 — 05:43 PM
I found the problem. I had some faulty wiring on the field coil. Unfortunately, now I'm getting low voltage on the plate...bluecap — 05:21 PM
There are currently 2323 online users. [Complete List]
» 3 Member(s) | 2320 Guest(s)
