Philco Radio Model 14 Code 122
Hi
What you need is a 6 pole, 2 position rotary switch. I believe you may be able to get such a switch from Mouser Electronics, but you will probably have to come up with a way to lengthen the shaft to use in your radio. I bought one from them a few years ago for a Model 29 chassis that I never did restore.
http://www.mouser.com/
Philco Radio Model 14 Code 122 - by Guest - 03-16-2009, 02:00 PM
Re: Philco Radio Model 14 Code 122 - by Ron Ramirez - 03-22-2009, 02:15 PM
Re: Philco Radio Model 14 Code 122 - by Guest - 03-23-2009, 03:58 AM
Re: Philco Radio Model 14 Code 122 - by Guest - 03-23-2009, 01:28 PM
Re: Philco Radio Model 14 Code 122 - by planigan - 03-27-2009, 12:45 AM
Re: Philco Radio Model 14 Code 122 - by planigan - 03-28-2009, 12:22 AM
Re: Philco Radio Model 14 Code 122 - by Guest - 03-28-2009, 07:33 PM
There are currently 6729 online users. [Complete List]
» 2 Member(s) | 6727 Guest(s)
