Working on repro Philco brass capacitor cans
If you would like to try using copper foil instead of paint drop me a note with your street address and I will be glad to send a couple of feet the stuff is 8 or 10 inches wide. David
RE: Working on repro Philco brass capacitor cans - by David - 11-01-2015, 06:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
