Working on repro Philco brass capacitor cans
I am not sure how copper foil will work. First there will be a seam. And if there is a wrinkle, good luck trying to smooth it out.
RE: Working on repro Philco brass capacitor cans - by morzh - 11-01-2015, 06:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
