Philco 8B56 clock
Well, the clock repair guy looked at it and said he really didn't want to get into the mechanism as it would be quite a job.  He believes that one of the gears in the time resetting mech is frozen and it needs to be disassembled and perhaps even a new part fashioned.  So, I put it all back together, refinished the cabinet and my wife found a spot for it to sit.  I'll plug it in at the right time and be done with it for now.
[Image: https://www.dropbox.com/s/b0246zwmw1k54y....jpg?raw=1]
Philco 8B56 clock - by klondike98 - 10-22-2015, 05:19 PM
RE: Philco 8B56 clock - by mikethedruid - 10-22-2015, 07:03 PM
RE: Philco 8B56 clock - by klondike98 - 10-22-2015, 07:31 PM
RE: Philco 8B56 clock - by OldRestorer - 10-22-2015, 07:35 PM
RE: Philco 8B56 clock - by klondike98 - 10-22-2015, 07:39 PM
RE: Philco 8B56 clock - by klondike98 - 11-01-2015, 08:34 PM
RE: Philco 8B56 clock - by OldRestorer - 11-01-2015, 08:53 PM
RE: Philco 8B56 clock - by klondike98 - 11-02-2015, 12:05 AM
There are currently 11336 online users. [Complete List]
» 2 Member(s) | 11334 Guest(s)
