Philco 8B56 clock
Icon_lol
The conversation with the clock guy did turn out to be interesting. He used to be an electronics tech repairing communications gear and was a ham. He collected cameras and in retirement became a camera and clock tech. So a fun day anyway.
Philco 8B56 clock - by klondike98 - 10-22-2015, 05:19 PM
RE: Philco 8B56 clock - by mikethedruid - 10-22-2015, 07:03 PM
RE: Philco 8B56 clock - by klondike98 - 10-22-2015, 07:31 PM
RE: Philco 8B56 clock - by OldRestorer - 10-22-2015, 07:35 PM
RE: Philco 8B56 clock - by klondike98 - 10-22-2015, 07:39 PM
RE: Philco 8B56 clock - by klondike98 - 11-01-2015, 08:34 PM
RE: Philco 8B56 clock - by OldRestorer - 11-01-2015, 08:53 PM
RE: Philco 8B56 clock - by klondike98 - 11-02-2015, 12:05 AM
There are currently 10528 online users. [Complete List]
» 2 Member(s) | 10526 Guest(s)
