Philco 95 Highboy Deluxe
(11-03-2015, 08:17 PM)PTurney Wrote:
(11-03-2015, 08:04 PM)morzh Wrote:  Where is the photo of yours?
Just follow the link to the page on my website.... I didn't want to post it here directly w/o resizing....
Ok, here's the smaller image from my 95 detail page.... Note the plaque above the escutcheon...
[Image: http://www.tuberadioland.com/images/tn_p...5Dlx_4.jpg]
Philco 95 Highboy Deluxe - by PTurney - 11-03-2015, 04:18 PM
RE: Philco 95 Highboy Deluxe - by morzh - 11-03-2015, 08:04 PM
RE: Philco 95 Highboy Deluxe - by PTurney - 11-03-2015, 08:17 PM
RE: Philco 95 Highboy Deluxe - by PTurney - 11-03-2015, 08:20 PM
RE: Philco 95 Highboy Deluxe - by Ron Ramirez - 11-03-2015, 10:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
