53-960 help with dial string
Brenda Ann
Yes I can see that pointer string diagram doesn't work. The lowest roller has three in on one side and only one out on the other. On first impressions I would try moving the right side pointer string to other side of the lowest roller.
53-960 help with dial string - by BrendaAnnD - 11-05-2015, 11:18 AM
RE: 53-960 help with dial string - by OZ4 - 11-05-2015, 01:04 PM
RE: 53-960 help with dial string - by OZ4 - 11-05-2015, 09:40 PM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 11:28 AM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 11:49 AM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 12:06 PM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 12:25 PM
There are currently 6532 online users. [Complete List]
» 1 Member(s) | 6531 Guest(s)
