Philco 366 problem with filter choke
Thought I'd butt in and mention that there are TWO chokes in the 366. One is the speaker field coil and the other is a separate discrete choke. The drill is pretty much the same.
I had a 366 and the separate choke in it was also fried. I did the resistor sub for it with no problems.
Philco 366 problem with filter choke - by Guest - 03-22-2009, 12:32 PM
Re: Philco 366 problem with filter choke - by Guest - 03-23-2009, 12:34 AM
Re: Philco 366 problem with filter choke - by exray - 03-23-2009, 08:23 AM
Re: Philco 366 problem with filter choke - by Guest - 03-28-2009, 01:42 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 2682 online users. [Complete List]
» 2 Member(s) | 2680 Guest(s)
