  • 1 Vote(s) - 5 Average
model 20 hum (detector circuit?)
#58
The voltages on det tube will be very different from the existing charts when read with a modern DMM. PLATE voltage will be on the order of 100V or so.
I restored two so far. Truthfully, the second time I did not bother checking voltages to be close to true values, all I bothered to do was (and often is with most radios) is making sure plate voltages look like.... plate voltages. As long as your radio is recapped/recarbed and your coils are OK, and tubes are good, the plate voltages will be good. I only start looking close if I have to troubleshoot.
model 20 hum (detector circuit?) - by Tubesforme - 10-19-2015, 01:11 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-19-2015, 06:23 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-20-2015, 10:01 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-25-2015, 10:57 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-25-2015, 11:39 AM
RE: model 20 hum (detector circuit?) - by morzh - 10-25-2015, 11:08 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 10:18 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 10:34 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-26-2015, 11:24 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-27-2015, 08:43 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-28-2015, 11:52 AM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-28-2015, 03:36 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-30-2015, 06:13 PM
RE: model 20 hum (detector circuit?) - by OZ4 - 10-31-2015, 10:40 AM
RE: Low continual hum in model 21 - by Tubesforme - 10-23-2015, 11:19 PM
RE: Need correct voltages for det and af model 20 - by morzh - 11-08-2015, 12:09 PM
Users browsing this thread: 19 Guest(s)
