Philco radio battery boxes
Kirk, what kind of radio do you want to make a battery for? There are lots of different sizes, voltages, and connector designs.
I have two old Philco batteries that I've made new guts for, using 9 volt and C or D cells. I can scan the boxes and send them to you if they're the kind you want. I'd have to look up the model numbers, but they are for a 41-81 and a 46-350.
Trouble is, I don't want to cut the boxes apart to make a flat scan of the whole box. I can make a scan of each side, but then someone would have to put them all together with photoshop or something to make a flat scan that could be printed out and folded to make a new box.
Old A/B batteries don't come up too often on ebay, Philco branded batteries even less. You often see B batteries with 67 1/2 or 45 volts, mostly Eveready, but sometimes other brands.
John Honeycutt
Philco radio battery boxes - by OldRestorer - 11-02-2015, 07:35 PM
RE: Philco radio battery boxes - by sam - 11-02-2015, 08:24 PM
RE: Philco radio battery boxes - by Radioroslyn - 11-02-2015, 10:18 PM
RE: Philco radio battery boxes - by sam - 11-02-2015, 11:20 PM
RE: Philco radio battery boxes - by codefox1 - 11-02-2015, 11:32 PM
RE: Philco radio battery boxes - by Arran - 11-03-2015, 01:57 AM
RE: Philco radio battery boxes - by Arran - 11-03-2015, 01:49 AM
RE: Philco radio battery boxes - by Arran - 11-03-2015, 02:13 AM
RE: Philco radio battery boxes - by OldRestorer - 11-03-2015, 07:25 AM
RE: Philco radio battery boxes - by sam - 11-03-2015, 12:50 PM
RE: Philco radio battery boxes - by OldRestorer - 11-03-2015, 05:26 PM
RE: Philco radio battery boxes - by klondike98 - 11-03-2015, 06:45 PM
RE: Philco radio battery boxes - by OldRestorer - 11-03-2015, 10:35 PM
RE: Philco radio battery boxes - by sam - 11-04-2015, 03:02 PM
RE: Philco radio battery boxes - by OldRestorer - 11-04-2015, 05:13 PM
RE: Philco radio battery boxes - by Raleigh - 11-08-2015, 05:14 PM
RE: Philco radio battery boxes - by sam - 11-08-2015, 07:29 PM
RE: Philco radio battery boxes - by Warren - 11-09-2015, 12:24 AM
RE: Philco radio battery boxes - by Warren - 11-09-2015, 03:52 PM
RE: Philco radio battery boxes - by OldRestorer - 11-09-2015, 09:51 AM
RE: Philco radio battery boxes - by AI2V - 11-09-2015, 11:57 AM
RE: Philco radio battery boxes - by OldRestorer - 11-10-2015, 08:32 AM
RE: Philco radio battery boxes - by OldRestorer - 11-10-2015, 08:33 AM
RE: Philco radio battery boxes - by Warren - 11-10-2015, 02:30 PM
RE: Philco radio battery boxes - by Warren - 11-13-2015, 12:29 AM
RE: Philco radio battery boxes - by OldRestorer - 11-13-2015, 06:14 AM
RE: Philco radio battery boxes - by mikethedruid - 11-13-2015, 12:04 PM
RE: Philco radio battery boxes - by Warren - 11-13-2015, 04:15 PM
RE: Philco radio battery boxes - by mikethedruid - 11-13-2015, 05:38 PM
RE: Philco radio battery boxes - by DeckApe - 11-21-2015, 04:51 PM
RE: Philco radio battery boxes - by Warren - 11-22-2015, 06:48 PM
RE: Philco radio battery boxes - by OldRestorer - 11-23-2015, 06:33 PM
RE: Philco radio battery boxes - by Warren - 11-25-2015, 01:32 AM
RE: Philco radio battery boxes - by Warren - 11-28-2015, 10:48 PM
RE: Philco radio battery boxes - by Warren - 11-29-2015, 11:16 PM
RE: Philco radio battery boxes - by OldRestorer - 11-30-2015, 12:45 PM
RE: Philco radio battery boxes - by Warren - 11-30-2015, 05:41 PM
RE: Philco radio battery boxes - by sam - 11-30-2015, 07:43 PM
RE: Philco radio battery boxes - by Warren - 11-30-2015, 10:41 PM
Users browsing this thread: 16 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
