  • 1 Vote(s) - 3 Average
noobie wow!!!! overwhelming. HELP
Finally got the bakelites taken care of. Turned it on and got a low buzz. I got some voltage readings and 78 rf looks bad.
i'm going back double checking things. Here are my readings:
TUBE.............................MY READINGS...................................... TEXTBOOK READING
80 rect:....................... F-F 4.93........P-P 740v.............................F-F 5.0.......p-k (p-p?) 350v
78 IF:..........................F-F 5.98......p-k 220v............................ F-F 6.3...... p-k........ 210
75 2cd det.................. F-F 5.9........ p-k 202v..............................6.3............ p-k........ 120
42 driver 2cd A.F.........F-F 5.98.......p-k 236v..............................6.3............p-k........ 205
6a7.............................F-F 6.0........ p-k 271................................6.3........... p-k..........210
78 RF.......................... F-F 6.01........p-k 4v.............................6.3........... p-k.......... 210
42 output.................... F-F 6.09.......p-k 291v.............................6.3.............p-k......... 280
42 output.....................F-F 6.15......p-k 291................................6.3........... p-k...........280
noobie wow!!!! overwhelming. HELP - by laipplyken - 10-31-2015, 10:35 PM
RE: noobie wow!!!! overwhelming. HELP - by Arran - 11-01-2015, 12:41 AM
RE: noobie wow!!!! overwhelming. HELP - by morzh - 11-01-2015, 11:16 AM
RE: noobie wow!!!! overwhelming. HELP - by Arran - 11-02-2015, 02:38 AM
RE: noobie wow!!!! overwhelming. HELP - by sam - 11-01-2015, 02:22 PM
RE: noobie wow!!!! overwhelming. HELP - by sam - 11-01-2015, 04:31 PM
RE: noobie wow!!!! overwhelming. HELP - by morzh - 11-01-2015, 04:42 PM
RE: noobie wow!!!! overwhelming. HELP - by laipplyken - 11-08-2015, 08:48 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-09-2015, 04:28 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-09-2015, 10:02 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-10-2015, 11:02 AM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-10-2015, 02:54 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-10-2015, 09:29 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-11-2015, 12:27 PM
There are currently 6722 online users. [Complete List]
» 2 Member(s) | 6720 Guest(s)
