  • 1 Vote(s) - 3 Average
noobie wow!!!! overwhelming. HELP
From your voltage readings it seems as thou your  primary of your 1st IF transformer is open.  Measure the HV on the connections of the transformer (IF). If you are lucky  you won't find any HV there, meaning that the loss of HV is somewhere else or a broken coil lead inside the IF can. Short of that you'll need to replace that transformer.
noobie wow!!!! overwhelming. HELP - by laipplyken - 10-31-2015, 10:35 PM
RE: noobie wow!!!! overwhelming. HELP - by Arran - 11-01-2015, 12:41 AM
RE: noobie wow!!!! overwhelming. HELP - by morzh - 11-01-2015, 11:16 AM
RE: noobie wow!!!! overwhelming. HELP - by Arran - 11-02-2015, 02:38 AM
RE: noobie wow!!!! overwhelming. HELP - by sam - 11-01-2015, 02:22 PM
RE: noobie wow!!!! overwhelming. HELP - by sam - 11-01-2015, 04:31 PM
RE: noobie wow!!!! overwhelming. HELP - by morzh - 11-01-2015, 04:42 PM
RE: noobie wow!!!! overwhelming. HELP - by Radioroslyn - 11-09-2015, 08:00 AM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-09-2015, 04:28 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-09-2015, 10:02 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-10-2015, 11:02 AM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-10-2015, 02:54 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-10-2015, 09:29 PM
RE: noobie wow!!!! overwhelming. HELP - by OZ4 - 11-11-2015, 12:27 PM
There are currently 5926 online users. [Complete List]
» 2 Member(s) | 5924 Guest(s)
