Philco 37-690 with a 38-690 Chassis??
There are many documented examples of Philco installing a chassis from one year into a cabinet of a previous or successive year. I have a 38-2650 in a 37 cabinet.
Does the tube diagram inside your cabinet have the 37-690 or 38-690 tube layout? This would be a key bit of evidence.
Philco 37-690 electrical restoration - by cwysong - 05-04-2015, 08:58 PM
RE: Philco 37-690 with a 38-690 Chassis?? - by TA Forbes - 11-10-2015, 11:53 AM
