philco 660
If its like my 630 there is a split washer type thingie on the front of the hub. It twists 90 degrees for removal. You can use needlenose pliers as a tool.
(Note from site admin: Sorry, but the photo which was attached to this post is no longer available.)
philco 660 - by philco phan - 03-21-2009, 07:13 PM
Re: philco 660 - by Chuck Schwark - 03-23-2009, 09:58 AM
Re: philco 660 - by philco phan - 03-23-2009, 01:18 PM
Re: philco 660 - by philco phan - 03-25-2009, 02:12 PM
Re: philco 660 - by exray - 03-25-2009, 02:59 PM
Re: philco 660 - by philco phan - 03-25-2009, 03:18 PM
Re: philco 660 - by philco phan - 03-27-2009, 08:56 PM
Re: philco 660 - by Ron Ramirez - 03-27-2009, 09:43 PM
Re: philco 660 - by philco phan - 03-27-2009, 10:08 PM
Re: philco 660 - by Ron Ramirez - 03-27-2009, 11:23 PM
Re: philco 660 - by planigan - 03-27-2009, 11:47 PM
Re: philco 660 - by philco phan - 03-27-2009, 11:48 PM
Re: philco 660 - by philco phan - 03-29-2009, 11:19 AM
There are currently 9766 online users. [Complete List]
» 3 Member(s) | 9763 Guest(s)
