1936 116-122 Cabinet Restoration
I found this ad in some of my grandfathers things for your radio
RE: 1936 116-122 Cabinet Restoration - by Arran - 10-19-2015, 04:25 AM
RE: 1936 116-122 Cabinet Restoration - by Arran - 10-20-2015, 11:45 PM
RE: 1936 116-122 Cabinet Restoration - by OldRestorer - 11-12-2015, 12:07 AM
