Bakelite blocks in a 37-116????
(11-13-2015, 03:58 AM)Arran Wrote:  Dan;
  Is this set a 37-116 or a 37-3116? The reason I ask is that the Canadian set may differ in some ways from most of the U.S built versions, but match up with others depending on the production run and Code number. From what I have heard, never having actually worked on a 1937-38 vintage Philco, is that the chassis are modular, they are made up of sections with plates and screws holding them together with wires connecting the various sections to each other. So to gain access to things you can remove plates and even whole sections if you have to. Bob Andersen's 37-640 restoration series was very enlightening in this respect.
Hi Arran, the radio is a philco 37-116. I see that the r-f section does come off and it looks like a pain. I did find some info from others on this forum that have remove that part of the chassis. one person said he was able to get to the caps to  without removing the r-f- chassis. I don’t see how , but could have been done. i’m going to take a look at it and assess the situation, but it looks like I'll be removing it, but first i’m going to recap the bakelite block!!! Thanks for your input. Jeff
Bakelite blocks in a 37-116???? - by Dan Walker - 01-08-2015, 02:36 PM
RE: Bakelite blocks in a 37-116???? - by David - 01-08-2015, 02:42 PM
RE: Bakelite blocks in a 37-116???? - by Kestas - 01-08-2015, 07:36 PM
RE: Bakelite blocks in a 37-116???? - by Warren - 01-08-2015, 07:46 PM
RE: Bakelite blocks in a 37-116???? - by 462ron - 01-08-2015, 08:00 PM
RE: Bakelite blocks in a 37-116???? - by morzh - 01-08-2015, 11:35 PM
RE: Bakelite blocks in a 37-116???? - by Nick3092 - 01-09-2015, 12:03 AM
RE: Bakelite blocks in a 37-116???? - by Arran - 11-13-2015, 03:58 AM
RE: Bakelite blocks in a 37-116???? - by radio jeff - 11-13-2015, 03:43 PM
There are currently 6158 online users. [Complete List]
» 1 Member(s) | 6157 Guest(s)
