Electrolytic Capacitor for PHILCO 41-290
Hi,
It is a dual cap. The red should tie into the field coil and be the 16mfd or the replacement 20 mfd. The blue should tie into the junction of the 18K and 33K resistor and use the 10mfd cap. The negative leads should tie together and go to the black lead to chassis ground. Check the old cap and see if it marked on the cap body anywhere. These caps should also have a voltage rating of 450v.
Hope this helps
[No subject] - by Terry Burns - 01-01-2006, 01:16 PM
