Need Help with 49-405 Electronics
Just for the fun of it if you would like to experiment a bit to remove hum disconnect R-100 and replace it with a small iron core choke. This can be one from a power supply, the HV secondary from a power transformer (disconnected of course) or it could be the primary of the tube type audio output transformer. Two things will happen one is that a choke is much better in filtering than a resistor and the other it has less of a voltage drop. So you'll get less hum and a little increase the voltage.
ps Grew up near where your bro lives. I'm from Sandy Spring about 15min from the other SS.
Need Help with 49-405 Electronics - by Winky Dink - 11-08-2015, 04:03 PM
RE: Need Help with 49-405 Electronics - by Radioroslyn - 11-14-2015, 11:03 AM
RE: 49-504 Trimmer Trouble - by Winky Dink - 11-19-2015, 04:18 AM
There are currently 4655 online users. [Complete List]
» 1 Member(s) | 4654 Guest(s)
