Philco radio chassis - I think
I just obtained a gorgeous Silvertone "Grandmother" clock/radio. The radio chassis has 1- 80tube, 2- 45 tubes, 3- 24A tubes. I think this is a Philco mfg. chassis - I'm I correct? It was mfg. between 1931-1932. The 45 tubes are the "balloon" type. Thanks, Phil
Philco radio chassis - I think - by phil vanderoef - 03-28-2009, 08:13 AM
There are currently 8480 online users. [Complete List]
» 2 Member(s) | 8478 Guest(s)
