need help identifying a Philco model. Also what kind of capacitors are used in thi
Here's some must read for first timers
http://www.antiqueradio.org/begin.htm
The photofinish described in the gallery link is a finish you can not strip, it will disappear and you will be left with a very plain wood.
There are currently 6467 online users. [Complete List]
» 1 Member(s) | 6466 Guest(s)
