Phlaky Lacquer
I cant tell if that is photofinish...
If it isnt then you will have to strip it. No way to match the toner and the flaking is too unstable.
If it is photofinish you can recreate it on a computer or if you have artistic talents then you can do it with paints.
I completely redid the photofinish on a philco radio clock lamp and it was not that hard.
First we need to know what the finish is.
Kirk
Phlaky Lacquer - by RodB - 11-19-2015, 07:03 PM
RE: Phlaky Lacquer - by OldRestorer - 11-19-2015, 08:08 PM
RE: Phlaky Lacquer - by RodB - 11-20-2015, 05:36 PM
