Philco Radio Model 14 Code 122
Planigan,
This is Radiojunkie and I would like to thank you for replying to my message.
You can reach me at Johnson5530@comcast.net to download the drawings.
I am sorry but I do not have any clear schems of the set.
I wish I could find them without having to pay for them.
If you have Riders volume 4 or know someone who does, then you can get some
better schems of the set to help you.
Hope to hear from you soon
Sincerely,
Radiojunkie
Philco Radio Model 14 Code 122 - by Guest - 03-16-2009, 02:00 PM
Re: Philco Radio Model 14 Code 122 - by Guest - 03-23-2009, 03:58 AM
Re: Philco Radio Model 14 Code 122 - by Guest - 03-23-2009, 01:28 PM
Re: Philco Radio Model 14 Code 122 - by planigan - 03-27-2009, 12:45 AM
Re: Philco Radio Model 14 Code 122 - by planigan - 03-28-2009, 12:22 AM
Re: Philco Radio Model 14 Code 122 - by Guest - 03-28-2009, 07:33 PM
