Loose tuning capacitor on model 70
No doubt the rubber grommets which serve to cushion the tuning condenser from the chassis are returning to the dust from whence they came. In other words, they are shot and require replacement.
Some sources:
dpatterson002 AT comcast DOT net - Don Patterson sells replacement grommets.
http://www.renovatedradios.com/parts.html - Renovated Radios also carries a selection of replacement grommets including those to fit the Model 70.
Re: Loose tuning capacitor on model 70 - by Ron Ramirez - 03-28-2009, 09:50 PM
