NEW Question: 38 116 dial mechanism and dial scale alignment
I have it set up properly now.
There are two detents on the dial, 180 degrees apart from each other.  One is very small, the other is larger and more noticeable.  The larger one is the wrong one.  I was using that one to slide over the keyway on the mechanism.
The other is very small and I never noticed it until today.  It is the right one and slides over the keyway and puts the dial in alignment
I need stronger glasses!
There are currently 5363 online users. [Complete List]
» 1 Member(s) | 5362 Guest(s)
