Push back wire
The unrated wire Ron mentioned is available as both stranded and solid. It is called small profile and does not carry the 600v rating. See:
http://www.radiodaze.com/cloth-covered/
Push back wire - by Stan the Man - 11-21-2015, 10:51 AM
RE: Push back wire - by Ron Ramirez - 11-21-2015, 12:49 PM
RE: Push back wire - by Stan the Man - 11-21-2015, 04:37 PM
RE: Push back wire - by Tubesforme - 11-21-2015, 10:38 PM
RE: Push back wire - by kiwi_steve - 11-22-2015, 06:44 PM
RE: Push back wire - by klondike98 - 11-21-2015, 10:49 PM
RE: Push back wire - by Crist Rigotti - 11-22-2015, 10:44 PM
There are currently 5904 online users. [Complete List]
» 2 Member(s) | 5902 Guest(s)
