Rare 1937 Philco 650px radio /phono
Yes indeed, I cant believe nobody bid on it except me! Took it home for a $20 and did power it up with varaic with positive results, hums . Shadow meter works and speaker is good, transformer checks ok and cant wait to get going on restoration. I do have a correct tone arm assembly that I can take out of another radio /phono set if need be. This radio is a lot bigger than it looks, biggest round dial of that style and is very heavy. Looks to be original finish although there are no decals around the nobs?
RE: Rare 1937 Philco 650px radio /phono - by Fred Taylor - 11-22-2015, 02:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
