Philco 118 cathedral
Well, 118s are a good radio, for this price you can't go wrong.
Enjoy!
Philco 118 cathedral - by Fred Taylor - 11-22-2015, 10:40 PM
RE: Philco 118 cathedral - by morzh - 11-22-2015, 11:32 PM
RE: Philco 118 cathedral - by palegreenthumb - 11-23-2015, 03:22 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
