My new Philco C-1343
You can't get carts anymore but you can still get styli from eBay or the other online sources. New styli might help, your's looks roached. I tried rebuilding one of those carts with a homegrown Rochelle salt crystal and had some success. I need to get my 51-1330 recapped and get the M-22 rebuilt so I can try for a better result. These might be better candidates for piezo wafer rebuilds since they take such a tiny element.
My new Philco C-1343 - by OldRestorer - 11-23-2015, 07:19 AM
RE: My new Philco C-1343 - by Squire - 11-23-2015, 04:04 PM
RE: My new Philco C-1343 - by OldRestorer - 11-23-2015, 05:40 PM
RE: My new Philco C-1343 - by Squire - 11-23-2015, 07:00 PM
RE: My new Philco C-1343 - by OldRestorer - 11-23-2015, 08:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
