Solid State Vibrator Replacement Circuit
That is the result of a setting I made in the phpBB setup, so that pictures can be no wider than 1000 pixels.
Know how some photos scroll way off to the right on the Antique Radio Forum, which of course makes the text scroll way off to the right as well? Like many of you, I do not care for that. So I chose to limit the width of pictures posted to the Phorum to eliminate the scrolling.
I suggest that if you use Photobucket or other hosting, that you post a smaller photo here then include a link to a larger one on Photobucket (or wherever your photos are hosted). This should solve the problems.
Or do what Exray said. ;)
Re: Solid State Vibrator Replacement Circuit - by Ron Ramirez - 03-29-2009, 08:00 PM
There are currently 10233 online users. [Complete List]
» 1 Member(s) | 10232 Guest(s)
