Need picture of the back of a Philco 38-60B
(11-24-2015, 12:29 AM)klondike98 Wrote:  Welcome to the Phorum!
Icon_wave
I do not believe Philco had backs on those.
Update..a quick search of the Phorum and I found Ron saying no US made cathedral or tombstone made before1939 had a back.  See
http://philcoradio.com/phorum/showthread...5#pid11805
Thanks for the prompt response, it was appreciated and I believe correct as all of the images I can find do not have a back on them. My only hint that there might have been a back at one time was the fact that with a great imagination I thought it looked like there was some tiny nail holes in the back on the cabinet.
Have a great Thanksgiving,
Don
RE: Need picture of the back of a Philco 38-60B - by pharmington - 11-24-2015, 02:19 AM
There are currently 9150 online users. [Complete List]
» 1 Member(s) | 9149 Guest(s)
