Philco 511 transformer smell
Hi Mark,
 Welcome to the Phorum!
The transformer should not get so hot the you can't hold your hand on it. If it does, remove the rectifier and try again, the transformer should barely get warm. If the transformer gets hot with the rectifier removed, it is bad.
M R Radios   C M Tubes
Philco 511 transformer smell - by mgandalf - 11-24-2015, 10:17 AM
RE: Philco 511 transformer smell - by klondike98 - 11-24-2015, 11:59 AM
RE: Philco 511 transformer smell - by Steve Davis - 11-24-2015, 12:43 PM
RE: Philco 511 transformer smell - by mgandalf - 11-24-2015, 05:01 PM
RE: Philco 511 transformer smell - by mgandalf - 11-24-2015, 05:15 PM
RE: Philco 511 transformer smell - by Arran - 11-25-2015, 12:08 AM
RE: Philco 511 transformer smell - by Steve Davis - 11-25-2015, 12:38 AM
RE: Philco 511 transformer smell - by Phlogiston - 11-25-2015, 12:26 PM
RE: Philco 511 transformer smell - by codefox1 - 11-26-2015, 01:40 PM
RE: Philco 511 transformer smell - by mgandalf - 11-30-2015, 02:14 PM
RE: Philco 511 transformer smell - by codefox1 - 12-01-2015, 05:22 PM
There are currently 4557 online users. [Complete List]
» 1 Member(s) | 4556 Guest(s)
