116B LO issue
THAT is some nifty troubleshooting, Brenda! Icon_thumbup Icon_thumbup
I'm calling this problem fixed. 8 hours and nary a hint of a problem. Tonight, I repaired the LW trimmer mounts and got that all set up, though it didn't take a lot of work, the actual adjustment changed just a very tiny bit. Also replaced the paper caps that were still left in the tone control. I can't believe how nice this radio sounds, given that about 40% of the cone is gone.
Now I'm waiting for a replacement dial disc from RadioDaze and the chassis is finished. Tomorrow, I'll start work on the cabinet. Wish me luck.
Great. Nice to hear it's working. Icon_thumbup  Now can you do paper mache?
Oh yea and whatever happened with that radio with the dial string issue?
That dial string issue is still an issue, since I honestly have no idea whatsoever how to make it work.
Hey Brenda, what's the trouble with the
vernier drive on that 116?
I may have the info to help you...
"Tune In, Turn On, Drop Out . . ."
Philco Guy No. 2
8)
Old, but not forgotten..........yet.
The problem is that I simply cannot decipher the silly thing. Needs to be restrung, but I've never seen anything remotely like it, and even with the string diagram on the paperwork, I still can't make sense of it. Icon_sad
There are currently 5386 online users. [Complete List]
» 1 Member(s) | 5385 Guest(s)
