Philco 38-7 auto tuning mechanism data?
Hello all, I am getting my 38-7 chairside almost to the point of being done. Would anyone be so kind as to post the instruction form #39-5533 and/or the service bulletin #282; these describe the service data/ channel setting info. Thanks so much!!
FYI- I found this info on the "other" Philco website, the Philcorepairbench.
jeff
for a few bucks
chuck has great schematics with all the info
http://www.philcorepairbench.com/schematics.htm
well worth it
or check here at bottom of page
http://www.philcoradio.com/phorum/showth...hp?tid=215
sam
Plus one on what sam recommended. I have ordered schematics from Chuck and they have a lot of detailed info in them. Good luck
There are currently 5513 online users. [Complete List]
» 1 Member(s) | 5512 Guest(s)
