1937 dial glass
Lthe round one. What is my best bet on this, is it something I can order, or should I have a glass shop cut it out for me?
John
Las Vegas, NV USA
See
http://www.philcoradio.com/resourceb.htm#h
I believe Mark sells both plastic and glass dial covers.
There are currently 10532 online users. [Complete List]
» 2 Member(s) | 10530 Guest(s)
