Threads: 242
City: West Bend, Wisconsin
As in woe is me...
Just started work on restoring this model (I had previously restored a 41-265 console for a friend and liked it so much I sought out the table model version). When I took the chassis out of the cabinet, I knew something was amiss, as the speaker was just flopping around not mounted to anything. Held in place by the two wires attached to it. One of which had the end soldered to the pushbutton support bracket.
So, someone years and years ago substituted a permanent magnet speaker in place of the original electromagnetic one. The replacement speaker measures 2.8 ohms across the terminals, which is pretty darn close to the 3 ohms called for on the schematic. My question is, how can I safely make this speaker work in place of the original electromagnetic? I remember this was discussed in the past, and I seem to recall adding a resistor was in order, but if someone could point me in the right direction, that would be great. It may very well have worked, albeit not too well just flopping around in the cabinet.
Here's a link to a PDF file of the schematic. I have the code 121. And yes, I spent part of my Christmas Eve working on a radio ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) Merry Christmas!
http://www.nostalgiaair.org/pagesbymodel...013404.pdf
Threads: 27
City: Tehachapi. California
Greg
I would use about a 1k ohm at 10 watts to start. It looks like you need to drop 95volts across #54 what use to be the field coil.
The main things to watch for are the voltage at what looks like #38A the 4 uf cap 190v and how hot the resistor gets.
You will be able to tell how close the 1K is once it is up and running. You might even start with a 1.5k ohm.
[Image: http://philcoradio.com/phorum/images/smi...on_eek.gif] Chris
(This post was last modified: 12-24-2015, 08:46 PM by OZ4.)
Threads: 242
Alas, I was able to get the radio working with the existing permanent magnet speaker! The previous repairman evidently had the right idea, but only used a 500 ohm wirewound resistor. I replaced it with a 10 watt, 1250 ohm and it plays great. Voltages check out OK. I was also able to get the pesky band switch indicator light dial string restrung, so that works now too. Add to that setting the 5 station pre-sets to 5 local stations, and the set functions like it should have in 1941. Even that troublesome off/on pushbutton works!
Here are a couple of before and after restoration pics:
Before:
After:
Yes, I know I didn't use the correct grille cloth, but I had this on hand and quite frankly, I like it better than the original pattern. Incidentally, the fabric on the before restoration pic, as you can see, had been replaced sometime in the past with something that also wasn't correct. It was stained so I replaced it.
Believe it or not that is the original finish on the cabinet in the restored picture! There was that much grease and grime on the cabinet (the radio was probably used in a kitchen) that good 'ol GoJo and a soft bristle brush brought out the light wood original color stain again. All I had to do was touch up the black trim otherwise no other wood refinishing was done to the cabinet. The Tenite dial bezel was another story:
I had to carefully block and clamp the center section flat with wood then heat each end with a heat gun on low to VERY carefully bend each side panel back out again. It still wanted to spring back some despite several attempts, so finally I just used two tiny screws to hold each side flush to the cabinet. That and having to use clear silastic to glue the dial glass to it because everyone of those original little clips that held it in place broke with just the slightest touch. But that's all concealed inside the cabinet behind the dial back plate on the chassis. Steel wool and polishing compound brought the original sheen back to the bezel, so all in all it doesn't look too bad. It was just unfortunate that Philco used that stuff for dial bezels before the war. Of course they couldn't have imagined someone would still be using these radios 75 years later!
Threads: 242
To give you an idea of just how dirty this cabinet was, here is how the top looked before the GoJo treatment:
And here it is after:
Threads: 337
City: lawrenceville nj
WOW greg ![Icon_eek Icon_eek](https://philcoradio.com/phorum/images/smilies/icon_eek.gif)
looks great ![Icon_clap Icon_clap](https://philcoradio.com/phorum/images/smilies/icon_clap.gif)
lucky you with bezel
sam
Threads: 562
Greg,
Why "Alas"? Would you rather it did not work?
Threads: 242
Huh? Wow. A better question would be why the nit-picking of single words and the over analyzing of them? But to appease you, by "alas", I meant that by using a higher value resistor as suggested by Chris, ALAS it DID work. Sheesh...
What is "everything else?"
Quick progress report:
There are currently 5434 online users. [Complete List] » 1 Member(s) | 5433 Guest(s)
