Replacement Speaker Cones
Where is the best place to find replacement speaker cones?
Oscar
nv3g
NV3GA, hi. I picked these up on Antique Radio, for speaker cones electonix.com. Apparently they have 8" to 10" listed but to find 5" you have to use extension "/cata...s id/13890" for 5" and extension "/cata...s id/13891" for 6". The quotation marks are mine, just type extension as it appears with that space between s and id. If it doesn't work I'm sorry as it is copied exactly as posted on Antique. PL
