Philco 38-12
Is the grille cloth and are the knobs original on this?  Anyone know?
(01-13-2016, 03:45 PM)Art Hoch Wrote:  Is the grille cloth and are the knobs original on this?  Anyone know?
Hi Art,
The knobs look right but the grille cloth doesn't. I'm pretty sure this 38-12 has the original grille cloth:
Actually - you've got a 38-12T. But the same grille cloth and knobs appear to be used based on the photo gallery picture:
http://www.philcoradio.com/gallery/1938a.htm#q
I concur.  I just picked this one up last night.  Original grill cloth and knobs (and tobacco smoke and pet hair!).
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
