Philco 81 B Dial replacement
       BIG Question,,,I have a Philco 81B,,,which has the Police Band...On thee Dial,,does it show the 2nd Band,like a  Philco 620, or any other radio that has multi bands on it…Because , My doesn't have it,,,BUT I do have the switch for it,, just need a- alignment for it..---Thanks You all….
My 81B shows frequencies for the "police" band on the dial:
[Image: http://i326.photobucket.com/albums/k420/...g~original]
        Thank You,,Ron,,,,I don't have that on the scale,,,now know what to look for,,,Maybe I can find one New some were,,,will look for one,,,  Cheers
I did notice that one of are suppliers replacement dials lists the 80 and 81 using the same dial. I too have an 81 with an 80 dial on it.
        Well,,,,Mark Oppat says that he does NOT have thee dial with the S.W. numbers under the scale,---he has 27-5009 and B-7989 ,,and Radio Daze only has B-7989,,,soo,,,I must have B-7989 ---ALSO (my mistake on number before) ,,, So I presume that the one  ,,,that I would need  would be the B-7889,,,which I can not find,,,
There are currently 5430 online users. [Complete List]
» 1 Member(s) | 5429 Guest(s)
