Threads: 91
City: Jonesboro
State, Province, Country: AR
I had a few questions I was hoping someone could answer for me.
I picked up a 1936 model 610 chassis late last year. No cabinet. Now, I think the Tombstone version had a smaller 5 1/2" speaker. There was also a "bullet" version of the 610. What size speaker did it have
I'm contemplating building a "visible" radio with this. A clear, plastic cabinet, so the internals can be seen. I often do old radio events, and thought it would be interesting for folks to be able to see the radio's internals. Since I don't currently have a "bullet" radio, I thought it would make an interesting project.
I also picked up a 38-624, 6v battery set chassis, that has been outfitted in a 37-610 cabinet.
I know the 38-624 was made in a "bullet" style and a console style. Did both have the 8" speaker
Also, I plan to eventually restore it, and also hope to find a "bullet" cabinet. What other "bullet" style cabinets besides the 38-624 would this chassis fit in? I also want to try to restore to battery operation, so my next question is: in the "bullet" style cabinet, was the battery in the cabinet, or external?
Also, what size battery should I look for as far as Amp hours?
Appreciate any help or info anyone can offer.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Hi Jeff
The 610B tombstone uses a 5 inch (not 5-1/2") P-27 speaker with 1146 ohm field coil.
The 610T "Bullet" uses an 8 inch S-14 speaker with 1140 ohm field coil.
The 38-624T uses an 8 inch KR-17 (permanent magnet) speaker. I don't have info for the 38-624 console but the 1937 version (37-624J) uses a 10-1/2 inch HR-12 (PM) speaker.
A 38-624 chassis will fit any 37-610, 37-611, 37-620, 37-623, 37-624, 37-630, 37-640, 37-641, 38-620, 38-623, 38-624 and/or 38-630 cabinet.
If you are limiting yourself to "Bullet" cabinets: 37-610T, 37-611T, 38-620T, 38-623T, 38-624T.
The 6 volt battery for the 38-624 would have been outside the cabinet.
I'll let someone else answer the amp-hours question. You will need to determine the current draw of the filaments and the B+ if the service info does not give this info (and it should).
Threads: 91
City: Jonesboro
(01-31-2016, 08:32 AM)Ron Ramirez Wrote: Hi Jeff
Thanks much Ron!  Notes taken. This will be a big help in rounding up what I need for these projects. Once I round up what I need, I'll document the restorations/projects here on the Phorum.
Blessings,
Jeff W.
Jonesboro, Arkansas
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
