37-61 photofinish... ideas ?
yes, Mike, the 37-610 is a different set of decals, larger than the 37-60/61 cabinet. I am not sure if the 37-640 is still another set. Anyway, Hank, I will be interested in seeing your results. I think the color is actually probably pretty close to the original. I know from violin work that reddish varnishes yellow and turn browner looking with age.
