70 speaker
How do you know it is a 70 speaker?
I am buying some speakers and he doesnt remember which are which.
They need re-coning though. Do you want one Fredrick if it needs re-coning?
Me
(02-25-2016, 08:10 AM)OldRestorer Wrote:  How do you know it is a 70 speaker?
Me
Sure Kirk, the 70 speaker will have 3 wires coming off transformer to plug it instead of 4. Four wires are for the 90 with push pull other than that I think they are the same. Also I do have enough speaker grill cloth that you asked about, the gold color chain link pattern. PM me
Doesn't the 20 also have the 3 wires... How do I tell it from the 20?
Message me the total for the grill cloth if you are sure you want to sell it.
Me
The 20 speaker has four wires also has a nut on the back of the field frame.
M R Radios   C M Tubes
(02-25-2016, 11:26 AM)OldRestorer Wrote:  Doesn't the 20 also have the 3 wires... How do I tell it from the 20?
Me
OK Icon_eek I WILL
Well
Nut is not the tell-tell; some of 90 speakers look same as 70 but electrically are like 20 for pushpull version and like 70 in SE.
The 4 wires mean pushpull (20 and some 90s), 3 mean SE, 70 and some other 90s.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
