G Speaker - Silver Cone??
Guys - can someone tell me if any of the '20's era Philco speakers came with a silver/grey cone? I'm seeing a claim to such, but no clue if it's accurate. In my limited experience, I've not seen a silver or grey cone color on one of the old speakers. Any quick replies would be appreciated. Thanks!
"Ignorance is bliss...'til you have to fix a radio..."
That doesnt sound like any vintage Philco Spkr Ive ever run across before, but I havent seen all them anyways. Bet Ron or Chuck will be by soon to give your spkr question a definate answer. On a side-note, how are you enjoying your new loop-antenna you built? Those rascals "work" indeed!!??? Jus Checkin. Icon_wink
Hey, thanks T-Rocker and good to hear from you! Tuned loop is still going strong -- have it hooked up to a 9-S-263 Zenith console with tuning eye and sure is fun to watch it "lock in"! I need to make a couple more of them - and need to try out your stand design, too. I'll keep an eye out for more feedback on the speaker cone question -- sounds odd to me... C ya.
