Awesome combination
I'm sure you Philco fanatics already know about this sort of stuff, but it was new to me and an incredible discovery
I thought I'd share!
I was fortunate to buy an impeccable Philco Beam of Light Demonstration Record and below it is being played on my BOL.
Still a bit of hollow feedback at such high volume levels, but it sounds amazing during normal play.
[Video: http://www.youtube.com/watch?v=UveaMDLawRw]
 I have read threads here on the Phorum about the beam of light. This is the first one I seen and heard playing. You have a very nice radio and the beam of light record is really cool. Icon_thumbup
mr grumpy
thanks for sharing that
did not know of such a record for bol will have to look on ebay
sam
Beyond cool, I love Kate, thanks for sharing.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3622 online users. [Complete List]
» 1 Member(s) | 3621 Guest(s)
