I need the technical manual model 46-806
HI Eliot Ness, thank you very much for your reply and help try to follow your recommendations to see if I succeed.
regards
have you tried
http://videokarma.org/
or
http://www.vintage-radio.net/forum/index...0f8dc69cbd&
sam
Hello san, thank you very much for your answer, try to see if I succeed in these forums.
Thank you very much again and Greetings
Hello Eliot Ness, say:
"This radio was not sold in the United States so not not many collectors own one of these".
But I have seen in Radiomuseum, this radio was manufactured in the United States.
http://www.radiomuseum.org/r/philco_46_806.html
I have several Philco radios that were made in the US of A, but they were not sold there. Just because its made in America doesn't mean it was made for the American market...
There are no personal problems that can't be overcome with the liberal application of high explosives
Thank you very much once again for your answer kiwi_steve.
You're right in what you say, keep looking to see that find, and if not, as you say, we must make a specific support for a loudspeaker located.
