Tube Tester
Can anyone please advise where I might find a manual for a NRI Model 71 tube tester? I cannot seem to locate a good source. Thanks.
"Ignorance is bliss...'til you have to fix a radio..."
Have you tried the Yahoo group Manual_Exchange? It is worth a shot...
John in ID
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
