Tube Layout Label for 48-200 Code 121
Would anybody have a good scan of a Tube Layout Label for 48-200 Code 121 that is affixed to the underside of the cabinet? thanks
There's a decent picture at RadioMuseum:
http://www.radiomuseum.org/r/philco_48_2...e_121.html
Obviously it would need to be corrected for perspective and cleaned up.
Another picture:
http://www.capeoldradio.com/cor_radio.ph..._box=25498
(04-14-2016, 01:45 PM)Nathan Slingerland Wrote:  There's a decent picture at RadioMuseum:
Another picture:
Thanks for the links. I had seen those and was hoping to find something a bit better. I am going to see what  I can do with them. thanks again.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6730 online users. [Complete List]
» 1 Member(s) | 6729 Guest(s)
