What are these called?
Does anyone know what these are called and where I might get some? The hold the backs on. I bought some about a year ago but I don't remember where.
Eric
The Villages, FL
Renovated Radios used to sell them.
Gregb
Split pins is what they are called.
http://www.renovatedradios.com/assets/im...mounts.jpg
Thanks guys.
Eric
The Villages, FL
They still do, $1.25 each.  Joe
Joe
Yup. Bought 10 of them.
Eric
The Villages, FL
$1.25 each for a fraction of a gram piece of cheap nylon.....dos iz a gut gesheft. Icon_smile
Well Mike, since I couldn't find them at Walmart, I figured I had no choice!
Eric
The Villages, FL
Eric
I could almost swear I saw something like it way before I got into the hobby. And more than one time. But hey, they make it to the spec etc etc, so ....we pay 10 bucks for a knob for golly's sake. Bud you have to admit, it's a good return on material's cost Icon_smile
I don't think anyone is getting rich making knobs or those metal Trimounts.  Unfortunately those are all low demand products and can't be mass manufactured like the old days.  I've seen the process for making knobs and it is neither cheap or easy, plus the molds have a limited life before they have to be remade.
Buy a mold kit for $50 or $60 (plus dyes) and when your first few knobs come out the wrong color or with bubbles on the surface those $10 knobs don't look so bad anymore.  Same way with those Trimounts, buy the material to make them, cut or stamp them out and when you figure out your time is worth more than spending an afternoon trying to make a half dozen that look like crap, then $1.25 doesn't look so bad anymore.
We're just lucky someone is taking the time to make this stuff for us.  Since Larry Bordernero passed (Old-Time Replications) we've lost the source for many of the large Philco escutcheons unless someone takes on the task of making them again.
Thank you John! You worded that so much better than what I was thinking.
Thank goodness the folks are around that take the time and make the effort to do these reproductions for our very limited market. I am in manufacturing and know what costs are involved and we as a hobby should be jumping for joy that these repo items are even available and at the extremely LOW prices as well.
Sorry for the folks that think these things are priced high, THEY ARE NOT.
Gregb
Possibly a small split rivet could be used if one spread it open a little bit.
                                                              Henry
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6732 online users. [Complete List]
» 1 Member(s) | 6731 Guest(s)
