Grille Cloth for 1935 model 60B...what is closest available?
Is anyone reproducing the grille cloth used on the later style model 60B (with the bakelite escutcheon)?
http://philcoradio.com/gallery/1935a.htm#ad
If not, what is the closest looking to that pattern available (ie, what have other's been using on their 60..and 89B.. models for 1935)?
Here's exactly what you need:
http://www.radiodaze.com/grille-cloth-05-item-grc05/
Note the green stripes should run vertically (top to bottom), not horizontally as shown in their photo.
Icon_thumbup Many thanks, Ron!
Greg, you've probably figured this out but they aren't selling the single radio size for some reason... you have to choose the larger piece and pay the extra $9 (my 97 uses the same cloth and I've just ordered some of this the other day).
Cheers
There are no personal problems that can't be overcome with the liberal application of high explosives
Yep. I needed some for my model 89 too so it worked out ok.
